Cache corruption due to multiple WC login
Current last line in proe1.psf is
ENV=PTC_WF_ROOT=C:\PTC\%USERNAME%\PDM_WF_Client
What would the %USERNAME% be to reflect the Windchill user login?
As a WC admin it is a problem when sometimes you need to login to WC within Pro/E as orgadmin and other times as your actual user account. Would like a way to setup the .psf file so it creates the cache folder based on WC login and NOT the Windows login name.
