Cache vaults not being used
gchampoux
7-Bedrock
We deployed Intralink 9.1 M060 this week.
Now I'm starting to deal with various issues.
One thing I noticed is that the cache vaults are not being used at all.
Everything being checked in is going straight to the master vault.
For functionality, this is not a problem.
However, for our 2 remote sites, this causes check-in to be slow.
I suspect that I have some left-over xconfmanager setting from migration that is doing this.
Anyone know what needs to be updated?
Gerry
RandyJones
20-Turquoise
(To:gchampoux)
When I migrated I did this so the FileTransfer loader would map files directly to the Master Vault instead of the cache
vault:
xconfmanager -s wt.fv.forceContentToVault=true -t codebase/wt.properties
xconfmanager -s wt.fv.useVaultsForAllContent=false -t codebase/wt.properties
xconfmanager -p
When I finish the FileTransfer I renabled the cache vaults like this:
xconfmanager -s wt.fv.forceContentToVault=false -t codebase/wt.properties
xconfmanager -s wt.fv.useVaultsForAllContent=true -t codebase/wt.properties
xconfmanager -p
> Gerry
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
Randy,
Thank you!.
Would I be correct in assuming thatmust set these on the replica servers
as well as the master?
Gerry
