Can someone help me DisableExplicitGC
cswaner
Hello Gurus,
I am looking for the xconfmanager syntax to disable GC on my test server.
In production the wt.propterties reads:
wt.manager.cmd.MethodServer.nonibm.java.args=\ -XX\:NewSize\=1024m -XX\:MaxNewSize\=1024m -XX\:SurvivorRatio\=4 -XX\:PermSize\=72m -XX\:MaxPermSize\=256m -XX\:+DisableExplicitGC
Trying to get the same in my dev enviroment.
Thanks for the help.
Cam
MCAD Architect
Any easier way you can get this same setting in your development environment is to simply copy the property setting from the site.xconf of your production to the site.xconf file of your development environment, save the updated file in dev and then from Windchill shell execute
xconfmanager -p -v. After which you will need to restart Windchill.
Alexius C. Chukwuka
IT Analyst, SAP Platform Support
Global Hosting and Network Services
Deere and Company
One John Deere Place
Moline, IL 61265 USA
BenLoosli
(To:cswaner)
Disregard the massage that this file should not be manually edited.
Edit the file to add the DisableExplicitGC to the wt properety line and then just run Xconfmanager -p -v and restart Windchill.
Or copy and paste the line from production to development like Alexius said.
Hi Ben,
Thanks for the confirmation 🙂 . I have been gone from the WIndchill domain for a while now, and was not sure if it could still be done that way or not in WIndchill 10.x
Cheers
Alexius C. Chukwuka
Deere and Company
