You need Change Context in the context where the object is starting
and Create By Move in the destination context.
Steve D.
Quoting "Kelly, Andrew C" <->:
> I'm trying to move an assembly (CAD Documents) from one Product into
> another Product. I get an error "You cannot move these objects
> because you do not have the necessary permission to change context
> for one or more of its versions."
> Both Products use the same lifecycle. The Policy Administrator says
> that I have the following permissions for the state in both
> Products for EPM Documents:
> Read, Download, Modify, Modify Content, Modify Identity, Create By
> Move, Create, Change Domain, Delete
> Is there a missing permission or some other reason why I can't move
> this assembly?
> Pro/Intralink 9.1 M020
> Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics
> | +1 440 326 5555 | F: +1 440 284 1090
