Can we use Oracle Database Express Edition 11g Release 2 for WC Database instead of Oracle Standers or Enterprise
Neo
7-Bedrock
7-Bedrock
I am trying to install the Windchill but I don't have oracle enterprise or stander edition will it be possible to use Oracle Express Edition 11g for our Windchill Database installation
GaryMansell
(To:Neo)
While it may be technically possible to use it for a DEV environment (we don't use it), it is not usable for a PROD or TEST System.
These are the licensing terms for Express Edition:
Oracle XE is a free version of Oracle that is limited to 1 processor, 1 GB RAM and 4 GB of data. It is also limited to 1 database on a computer, since the database must be named XE which must be unique.
Oracle Standard Edition One is the cheapest route
Rgds
Gary
GaryMansell
(To:Neo)
Rgds
Gary
Neo
7-Bedrock
7-Bedrock
(To:GaryMansell)
Thanks Gray for your response,
so In that case I will have to keep my DB name XE only or I can change it ? as well
also can I use MySQL Server 5.5 to install the Windchill Database
GaryMansell
(To:Neo)
You would need to stick with using the DB name
MySQL is not supported as a DB - only Oracle or MS SQL Server
