Change Request - Proposed Solution - (Securedinformation)
Highlighted
Regular Member
Thanks! That did the trick. For testing purposes I set teamMembers,
All to Read and it worked.
I'll figure out what we need, and tweak accordingly.
Steve D.
Quoting "Villanueva, Antonio" <->:
> The object created when data is entered into Proposed Solution is a
> WTChangeProposal. There are separate ACLs for this. Check the policy
> administrator.
