Change task - New Revision label picker error
MikeLockwood
22-Sapphire I
Has anyone else seen the problem shown in attached? It's repeatable for this data set.
9.0 M050
Is there a message in the Catalina.out file under Tomcat? Try watching
that and the MS log when the error occurs. It might related to a
specific JSP or class that you can enable debug logging on. Is it
possible that one of the 73 items is a poison pill?
Found the issue - related to one WTPart in the list in the wrong context - no Read access enabled there. System seems to be working correctly.
This e-mail (including any attachments) is confidential and may be legally privileged. If you are not an intended recipient or an authorized representative of an intended recipient, you are prohibited from using, copying or distributing the information in this e-mail or its attachments. If you have received this e-mail in error, please notify the sender immediately by return e-mail and delete all copies of this message and any attachments.
Thank you.
