We have added a new unit of measure (UOM). It is desired to update all parts that use the OOTB 'each' UOM to use this new UOM. Also any BOM usages that use the OOTB 'each' we want to update those to the new UOM.
What would be the best way to do this?
thx
While I've never attempted this kind of change with UOM, I would think you could simply modify the UOM Resource Bundle leaving "ea" but changing the display name from "Each" to whatever your new value is. My suspicion is that this would handle the "change" while not actually being a change. Certainly an option to consider if you truly want to leave "Each" behind in the dust.
Russ
