Check-in
ptc-2957697
Check-in
I have a problem with check-in, when I try make a check-in of a drawing, I have a problem, made upload, but when go to make a check-in, show this mensage: Cannot create a reflexive UsageReference Link.
How make to resolve this problem?
Hi Marcelo, do you have the "auto associate to parts" button checked when you do the check in?
Your answer was correct, but I hade to use the "edit associate" and not "auto associate".
Thank's for your help.
LoriSood
23-Emerald I
(To:ptc-2957697)
I'm not sure what version of Windchill you're using, but either of the following may be applicable:
http://www.ptc.com/appserver/cs/view/solution.jsp?n=CS40409
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS101356
Hi Lori, I'm using the version 10.0.
Thank's for your help, but I managed to solve the problem.
I used the "edit associate part" and solve the problem.
