Code to check roles in a workflow
I have the code (below) to check if a role has someone assigned to it or not.  What I need is how to change the code to check for two different roles to make sure that they are both assigned.
wt.workflow.work.WfAssignedActivity act = (wt.workflow.work.WfAssignedActivity) self.getObject();
	wt.workflow.engine.WfProcess pro = (wt.workflow.engine.WfProcess) act.getParentProcess();
	wt.team.Team t = wt.team.TeamHelper.service.getTeam(pro);
	java.util.Map members = t.getRolePrincipalMap();
	java.util.Set keys = members.keySet();
	java.util.Iterator itr = keys.iterator();
	while (itr.hasNext()) {
		wt.project.Role role = (wt.project.Role) itr.next();
		System.out.println("Role-=-=-=" + role);
		if (role.toString().equalsIgnoreCase("MyCustomRole")) {
			java.util.ArrayList users = (java.util.ArrayList) members.get(role);
		//If there is no user in MyCustomRole role throw exception
			if (users.isEmpty()) {
			throw new Exception("Select user for " + role.getDisplay());
10 REPLIES 10
Re: Code to check roles in a workflow
You can consider something like that:
java.util.ArrayList<String> rolesToCheck = new java.util.ArrayList<String>();
rolesToCheck.add("MYCUSTOMROLE");
rolesToCheck.add("MYCUSTOMROLE2");
	if (rolesToCheck.contains(role.toString().toUpper()))) {
The roles must be uppercase and internal value.
That way, you can check as many roles you want.
Florent
Hello Florent,
I am using the internal name for my roles and capitalized them in my first line of code.  However my roles are not all capitalized.
I got the following error when checking syntax....
Checking Syntax...
Checking Syntax...
D:\ptc\Windchill_11.0\Windchill\temp\WfExpression188770479.java:56: error: illegal start of expression
1 error
Syntax check complete.
Brian
Sorry, I made a mistake.
Try replacing the first line with
Hello Brian,
I am looking for more concise code to stay within the 4000 Character Limit.
Did you find a solution to your code?  I see the same error when attempted the code in the Community Message as My Internal Names also are not all Capitalized.
I have code that will check a few roles but need to check 10 downstream roles which your code appears it would handle easily
Brian
To all,
in the first lines, you can either:
  • put the key of the roles you want to check in uppercase (no mater how the key is) or
  • put the key in the exact manner (as in RoleRB.rbInfo) and remove the toUpperCase()
rolesToCheck.add("<KEY OF THE ROLE1>");
rolesToCheck.add("<KEY OF THE ROLE2>");
	if (rolesToCheck.contains(role.toString().toUpperCase())) {
@BrianSullivan If you have length issues, you can remove the comments and System.out.print lines.
Florent ROUSSEL
www.4cad.ca
I'm getting the same error.  If I remove the .toString().toUpper() it passes the syntax check but still fails to run:
wt.workflow.engine.FailedExpressionException: wt.util.WTException: java.lang.ClassCastException: wt.workflow.engine.WfProcess cannot be cast to wt.workflow.work.WfAssignedActivity
Nested exception is: java.lang.ClassCastException: wt.workflow.engine.WfProcess cannot be cast to wt.workflow.work.WfAssignedActivity
Nested exception is: wt.util.WTException: java.lang.ClassCastException: wt.workflow.engine.WfProcess cannot be cast to wt.workflow.work.WfAssignedActivity
Any ideas?
Does this code have to go inside an activity?  I was trying to use it at the beginning of the workflow in an expression block but I think it might be failing due to no activities being assigned yet.  I'd like to make sure all the roles are populated before the activities are assigned...
@TomU Yes, I believe @BrianToussaint had this in the "Complete task" transition of a "Setup Participant" task.
Florent ROUSSEL
www.4cad.ca
Bummer.  I don't use any of those (and don't want to).  The users are supposed to assign users to the roles during creation (from the wizard.)  I'd love to find a way to prevent the wizard from finishing if the roles are empty...
