Is anyone running Cognos on a Windows 64 bit environment? I am cannot
get it to work and I received the following from PTC support indicating
it is not supported. That is sometimes different from "does not work".
Cognos8.2 is not supported on 64bit windows machine. Please find the
link mentioned below for your reference.
I would suggest you to stop the service and un-install the Cognos from
64bit and switch to 32 bit Machine to work with this tool.
