Creating WT Parts without Workflow
Highlighted
Newbie
Dear All,
Is it possible to create WT Parts without Workflow? Ourrequirement is, Part should run on Workflow, but Assemblies and Sub assemblies should not run on Workflow.
Since we need a Number for Assemblies and Sub assemblies, we are creating WT Parts for that. But It doesn't require to follow workflow. Now, We are manually terminating the Workflow.
Any suggestion would be appreciated.
S.Rajakumar
Highlighted
Raja,
The best practice is not to assign workflows directly to part and end items
but to advance them via Promotion Requests and/or Change Management objects.
If you have very specific processes that you want some parts (e.g. component
parts) to go through, then you can make a custom promotion or Change
Activity workflow.
If you must place workflows on the WTPart and END ITEM objects, you can add
an activity after start for the creator that either submits to or terminates
the workflow.
H. Lewis Kennebrew, II
Vice-President, Operations
ProductSpace Solutions, Inc.
"Your Products to the Nth Power"
2021 Midwest Road, Suite 200
Oak Brook, IL 60523
630-495-2999x8101
