Hi all,
Using Windchill PDMLink 10.2.
I have, in the past added custom attributes for EPMDocument usage links directly in the Type and Attribute Management , navigating to the EPMDDocument .
Also, custom attributes in Part Usage link.
But, here I want to add custom attribute in the link "References Document", however there is no Object Type like this (Similar to EPmDocument Usage Link or Part Usage Link).
There is only Document Uses link, but this is meant for the Document Structure Tab and not for the References Document in the Related Objects tab.
If there is no object type for this link, then only way is to study what is going into that link through the JCA debug or look at the Document tables in DB..
Is ther any way out?
Thanks & Regards
Hari
Hi
in Type Manager you've got the "Part reference" (wt.part.WTPartReferenceLink)
which is the WTpart to Document master link.
If I remember , I've an idea for that, ... cause the OOTB links Reference or Describe links, even if in Type manager, do not show the IBAs in UI .... at least in 10.0. may be now it's OK in 10.2
A Doc to Doc reference link does not exists in Windchill data model.
regards
Still not there in 10.2
Hi all,
Thanks for the replies, So what is the way out?
Rgds
Hari
Hi Hari,
Did you get a solution for this requirement ?
Thanks&Regards,
Shibin
