Custom Data Utility Multiline Text Display Issue After Upgrade
Anil_SAD
Version: Windchill 13.0
Use Case: Custom Data Utility Multiline Text Display Issue After Upgrade
Description:
Hi there,
I'm experiencing an issue with the display of multiline text from a custom Data Utility after upgrading our Windchill environment from version 11.2 to 13.0.
I've developed a custom Data Utility which is used to display specific text information, retrieved from an attached Excel document, on the Attributes-Structure tab of WTParts( Thanks to @HelesicPetr  for idea 🙂 ).
This text data is structured to include multiple lines for readability (e.g., containing section headers and descriptions).
In Windchill 11.2, this Data Utility successfully displayed the text with proper line breaks, effectively creating a multiline output within the UI field/cell where the Data Utility is rendered.
However, after upgrading to Windchill 13.0, the exact same Data Utility code now displays all the text as a single continuous line. The intended line breaks are ignored, making the displayed information difficult to read and interpret.
Steps Taken (Troubleshooting):
  1. I confirmed that the Data Utility logic correctly reads the data from the Excel file and builds the output string with standard newline characters (\n) at the intended break points.
  2. Based on the observation that \n characters were not being interpreted as line breaks in 13.0, we modified the Data Utility code to explicitly replace the newline characters (\n) with HTML <br> tags before setting the value to the TextDisplayComponent.
  3. Upon viewing the modified Data Utility output in Windchill 13.0, we observed that the <br> tags themselves are displayed as literal text within the UI, rather than being interpreted as HTML line breaks. This indicates that the output of the TextDisplayComponent is being escaped and treated as plain text by the rendering mechanism in Windchill 13.0, despite our attempts to insert HTML.
Expected Behavior:
We expect the custom Data Utility to display the text with proper line breaks, as it did in Windchill 11.2, for improved readability.
Thank you for your time and assistance.
Btw here my code snippet for set value for textcomponent:
// Seviye değiştiyse veya ilk seviye ise
    	if (level != null && !level.equals(currentLevel)) {
    	currentLevel = level;
    	if (combinedValues.length() > 0) {
    	combinedValues.append("\n");
    	combinedValues.append("----------------------------------------").append(currentLevel).append("----------------------------------------").append("\n");
    	if (text != null && !text.isEmpty()) {
    	combinedValues.append(text).append("\n");
    	return combinedValues.toString();
    	} catch (Exception e) {
    	System.out.println("Error processing Excel file for document: " + latestDoc.getNumber());
    	e.printStackTrace();
    	System.out.println("Error in getCombinedColumnAValues for part: " + part.getNumber());
    	return null;
    private TextDisplayComponent createTextDisplayComponent(String componentId, String value) {
        TextDisplayComponent textComp = new TextDisplayComponent(null);
        textComp.setId(componentId);
        textComp.setValue(value);
        textComp.setLongTextDisplayMode(true);
        textComp.disableMoreLink();
       // textComp.setTruncationLength(4000);
        textComp.setCheckXSS(false);
        return textComp;
Anil.
HelesicPetr
(To:Anil_SAD)
Hello @Anil_SAD
I've found a right component to use
very simple text with BR separator
results
 You just have to use RichText datautility and set a value
use extends com.ptc.core.components.factory.dataUtilities.RichTextDataUtility
and return a com.ptc.core.components.rendering.guicomponents.RichTextDisplayComponent
public class MyFunction extends RichTextDataUtility
	@Override
	public Object getDataValue(String componentId, Object datum, ModelContext mc) throws WTException
		Object retValue = super.getDataValue(componentId, datum, mc);
		if (retValue instanceof AttributeDisplayCompositeComponent)
			AttributeDisplayCompositeComponent dc = (AttributeDisplayCompositeComponent) retValue;
			RichTextDisplayComponent ricText = (RichTextDisplayComponent) dc.getValueDisplayComponent();
			String combinedValues = "text enter text </BR> system separator text </BR> text next row";
			if (combinedValues != null)
				ricText.setValue(combinedValues);
				return ricText;
		return null;
 PetrH
9 REPLIES 9
Fadel
23-Emerald I
(To:Anil_SAD)
take a look at https://www.ptc.com/en/support/article/CS362159 , change seems to be implemented in WC12
Fede
avillanueva
23-Emerald I
(To:Fadel)
@Fadel is right on. I had to recode some of my customization to account for Rich Text change.
HelesicPetr
(To:Fadel)
Hi @Fadel
I thought that the TextDisplayComponent is not the right component to use for the styled text output
PetrH
Anil_SAD
(To:Fadel)
Hi @avillanueva @Fadel @HelesicPetr
I've changed my component to HTMLText comp but its still single continuous line. Maybe my method is wrong about set value to this component,
Here my code snippet:
    	    System.out.println("Error in getCombinedColumnAValues for part: " + part.getNumber()); // Orijinal log
         System.out.println("Could not find valid data in any described-by Excel documents for part: " + part.getNumber() + ". Returning null."); // Ek log kaldırıldı
    	return null;
    private HTMLText createHTMLTextComponent(String componentId, String value) throws WTException {
         System.out.println("Creating HTMLText component for componentId: " + componentId);
        try {
            HTMLText htmlComp = HTMLText.newHTMLText(value);
            return htmlComp;
        } catch (WTPropertyVetoException e) {
             System.err.println("Error creating HTMLText component for componentId: " + componentId);
            throw new WTException(e);
    @Override
    public Object getPlainDataValue(String arg0, Object arg1, ModelContext arg2) throws WTException {
        // Product Structure Browser "Attributes" panel calls this.
    	System.out.println("Entering " + this.getClass().getName() + ".getPlainDataValue");
        if(arg1 instanceof WTPart) {
        	System.out.println("Returning Custom getPlainDataValue");
            WTPart part = (WTPart) arg1;
            try {
                 return getCombinedColumnAValues(part);
                 System.err.println("Error in getPlainDataValue calling getCombinedColumnAValues for part: " + part.getNumber()); // Log eklendi
                 e.printStackTrace(); // Orijinal hata basımı
                 return null;
        } else {
            System.out.println("Returning OOTB getPlainDataValue");
            return null;
Also i've tried this too
        try {
            String htmlValue = value.replace("\n", "<br/>");
            HTMLText htmlComp = HTMLText.newHTMLText(htmlValue);
            return htmlComp;
but it's the same the output is still single continuous line below.
Btw to workaround this issue, I've been looking for how to add my own "customizedTAB" to this panel. If i can add it i'll able to do everything i want with this customizedTab i think. I wanna place it right after Documents.
But as i remember @HelesicPetr 's old posts, it's difficult to customize these areas cause of its rendered by GWT.
I've found we're able add some sections to TAB on the top side. like this post(This is for ChangeRequest) Link
But i want to do add my own customized tab under stucture tab, so i need to find the ID of Default Attributes-Classifications-Visualization-Uses-Occurences ... to define them in custom-models.xml file.
I read almost 279 xml files in codebase\config\actions , so all i need is know is it feasible or not 🙂
HelesicPetr
(To:Anil_SAD)
Hi @Anil_SAD
What does a method getCombinedColumnAValues do? I would like to see a string output.
PetrH
Anil_SAD
(To:HelesicPetr)
Hi @HelesicPetr
I sent you a message with the full code of the class 🙂
By the way, I figured out how to hook into the GWT-rendered section, but it doesn’t behave like a tab. It works more like a button. It didn’t feel very useful to me, so I gave up on that approach.
If someone else wants to try it:
Just need to hook codebase\netmarkets\javascript\psb\psb.js but the the crucial point is just you need to call your function after the page fully loaded.
Anil.
HelesicPetr
(To:Anil_SAD)
Hello @Anil_SAD
results
	@Override
				return ricText;
		return null;
 PetrH
Anil_SAD
(To:HelesicPetr)
Hey @HelesicPetr
Thanks! It works perfectly with the Information Page Layout 🙂
I also had a problem with making the font style bold (I wanted to bold the "Level" part of this value), and I managed to solve that too using the same layout with a DU.
So this layout solves both of my problems because it's calling getDataValue as a function, which allows us to render the text as HTML.
It seems like the best practice is to let users access all the information about this part on its details page, maybe I can direct them to that instead.
Actually I was actually trying to do the same thing in the layout of the Part Structure Tab. That layout calls getPlainDataValue, and I think it always renders the value using .toString(), which strips out all HTML tags before rendering the content. So I guess it’s impossible to do this in the Part Structure Tab at least for me… maybe not for you, haha
Anil.
Hello @Anil_SAD,
It looks like you have some responses from some community members. If any of these replies helped you solve your question, please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
