Hi
I agree with Mike and Hugo.
I do not see a problem with the limitation in ProE. First, I think user should never be able to revise on the fly. Revising means an official change and someone how managed via the change management process.
If CM is implemented the CN should revise all the impacted object automatically. That is, when the user receive the task to apply the change the data is ready for him to check out.
If CM is not implemented, I personnally recommend to use Windchill to revise.
What are your best practices depending on if CM process is available or not ?
Best regards
