When configuring a workflow assignment, deadlines can be specified relative to the start of the parent process and/or relative to the start of the assignment. When both are set the earliest date is used.
I made a couple of tests
As pointed out by Al, deadline settings within process properties relate to the whole process.
I still wasn’t sure how this worked out in practice so I made a few tests. These are the conclusion I have reached so far, based on those tests. Once again PTC seem to have dropped a chapter out of the documentation.
The “Skip”, “mark complete” and “reassign” settings are shown in both cases as check boxes. In standard UI design this means they can be selected independently. In this case they should really be presented as radio buttons because you can only pick one from three.
From the Task Properties Deadline Tab
Deadline from start of activity and start of parent process mean what they say here.
Mark complete
Skip
Reassign
