Delete a Workspace by API
aemaeth.2501
I successfully created a workspace in a specific context, but now I would
like to delete it via API.
Looked in EPMWorkspaceHelper but didn't found anything.
Does anyone faced the same issue ?
Sincerely,
Thibault Magné
Hi Thibault,
Check if this works for you..
EPMWorkspace workspace;
PersistenceHelper.manager.delete(workspace);
Best Regards
Shudh Datta
shudh@shudh.me
2012/1/12 Thibault Magné <->
> Hi,
> Sincerely,
> Thibault Magné
The provided solution does not work unfortunately.
Sincerely,
Thibault Magné
Le 12 janvier 2012 11:51, Thibault Magné <-> a écrit :
> Hi,
> Thanks you very much for this, wasn't sure I could use directly the
> Sincerely,
> Thibault Magné
> Le 12 janvier 2012 11:49, shudh datta <-> a écrit :
> Hi Thibault,
>> Best Regards
>> Shudh Datta
>> shudh@shudh.me
>>> Hi,
>>> would like to delete it via API.
>>> Sincerely,
>>> Thibault Magné
Hi back,
I forgot to add the stacktrace:
Error while removing the temp workspace tempWs1337-1
wt.util.WTException: java.lang.NullPointerException
Nested exception is: java.lang.NullPointerException
at
wt.epm.workspaces.InitialCheckinDataManager.getInitialCheckinData(InitialCheckinDataManager.java:228)
at
wt.epm.workspaces.EPMStandardWorkspaceManager.getNewObjects(EPMStandardWorkspaceManager.java:1113)
at
wt.epm.workspaces.EPMWorkspaceManagerFwd.getNewObjects(EPMWorkspaceManagerFwd.java:910)
at
wt.epm.workspaces.EPMStandardBaselineService.processWorkspacesOnPreMultiDelete(EPMStandardBaselineService.java:2847)
at
wt.epm.workspaces.EPMStandardBaselineService.processPreMultiDeleteEvent(EPMStandardBaselineService.java:2597)
at
wt.epm.workspaces.EPMStandardBaselineService$8.notifyVetoableMultiObjectEvent(EPMStandardBaselineService.java:555)
at
wt.events.StandardKeyedEventBranch.intDispatchEvent(StandardKeyedEventBranch.java:441)
at
wt.events.StandardKeyedEventBranch.dispatchVetoableMultiObjectEvent(StandardKeyedEventBranch.java:385)
at
wt.events.StandardKeyedEventDispatcher.intDispatchEvent(StandardKeyedEventDispatcher.java:527)
at
wt.events.StandardKeyedEventDispatcher.dispatchVetoableMultiObjectEvent(StandardKeyedEventDispatcher.java:442)
at
wt.services.StandardManagerService.intDispatchVetoableEvent(StandardManagerService.java:715)
at
wt.services.StandardManagerService.dispatchVetoableMultiObjectEvent(StandardManagerService.java:591)
at
wt.fc.StandardPersistenceManager.dispatchVetoableEvent(StandardPersistenceManager.java:5451)
at
wt.fc.StandardPersistenceManager.dispatchVetoableEvent(StandardPersistenceManager.java:5423)
at
wt.fc.StandardPersistenceManager.delete(StandardPersistenceManager.java:2045)
at
wt.fc.StandardPersistenceManager.delete(StandardPersistenceManager.java:576)
at wt.fc.PersistenceManagerFwd.delete(PersistenceManagerFwd.java:171)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at
wt.method.MethodResultWriter.writeExternal(MethodResultWriter.java:151)
at wt.method.MethodResult.writeExternal(MethodResult.java:226)
at
java.io.ObjectOutputStream.writeExternalData(ObjectOutputStream.java:1418)
at
java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1390)
at
java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1150)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:326)
at sun.rmi.server.UnicastRef.marshalValue(UnicastRef.java:274)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:315)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at
sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
at
sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
at
sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Sincerely,
Thibault Magné
Le 12 janvier 2012 15:11, Thibault Magné <-> a écrit :
> Hi,
> Sincerely,
> Thibault Magné
>> Hi,
>> Sincerely,
>> Thibault Magné
>> Hi Thibault,
>>> Best Regards
>>> Shudh Datta
>>> shudh@shudh.me
>>>> Hi,
>>>> Sincerely,
>>>> Thibault Magné
>>>> -----End Original Message-----
Indeed I had a null value. My bad.
Thanks again,
Sincerely,
Thibault Magné
Le 12 janvier 2012 16:33, shudh datta <-> a écrit :
> Hello Thibault ,
> The code snippet, I sent to you is working fine in my solution. I see that
> it is a null pointer exception , could this be possible that some required
> value is null in your code or workspace is null??
> Best Regards
> Shudh
>> Hi back,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Sincerely,
>> Thibault Magné
>> écrit :
>> Hi,
>>> Sincerely,
>>> Thibault Magné
>>> écrit :
>>>> Hi,
>>>> Sincerely,
>>>> Thibault Magné
>>>> Hi Thibault,
>>>>> Best Regards
>>>>> Shudh Datta
>>>>> shudh@shudh.me
>>>>>> Hi,
>>>>>> Sincerely,
>>>>>> Thibault Magné
