David - What version of windchill are you running ? The DeleteRepUtil I'm running on 9.1 only allows deleting via list of OIDs, so we had to create some sql queries to firstfind the OIDs, then use the DeleteRepUtil.
Ed,
Once finshed reading the file the list object is passes to PersistenceHelper.manager.delete(list);
I did this
spool DerivedImage.txt create;
select ida2a2 from DerivedImage where CREATESTAMPA2<'14-JAN-2013';
spool off;
I then passed the output file to my tool which interestingly enough did exactly what the OOTB tool did except that my loop found the object and then imediately deleted it rather than add it to a list to be deleted as a bulk delete later on.
David
In Reply to Ed Howanice:
