Deploying WC 11.1 Load files, ACLs Load file fail to load during deployment in Fresh WC 12.0 Instanc
HS_9790478
2-Explorer
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.5
Deploying WC 11.1 Load files, ACLs Load file fail to load during deployment in Fresh WC 12.0 Instance.
ACL Load file are fail to load due to this error message. Need your help right syntax to load in WC 12.
Principal "cn=supplier administrators,o=corporate,ou=people,cn=administrativeldap,cn=windchill_11.1,o=cmiperf" not found.
Here are the errors that I faced
HelesicPetr
(To:HS_9790478)
Hi @HS_9790478
If the installation is new, why do you use windchill_11.1 in the string?
I guess that this principal really does not exists in the database or ldap
Correct the string to existing principal (user, group, role)
PetrH
