Is there a way to display mass properties of CAD documents from a list of part numbers? I have a list of numbers and can search/display them in windchill but would like to display the mass of each as well. I would also ultimately like to export the list to excel. Basically I want to add a column to the search that displays the mass of each item.
Thanks for any insight.
Do you have IBAs on the WTParts/CAD Docs that map to the mass properties parameters so that they can be displayed in Windchill?
If so you should be able to create a custom table view in the Search to include the IBAs that are defined on the Part type
