I can't seem to get the drawing setup file to load properly from Intralink 9.1
The config.pro option drawing_setup_file is set to "wtpub://ilink/Products/Library/Formats/setup.dtl"
(note that "Products/Library" is not a typo)
It never gets loaded automatically on drawing creation, but if I load it through Pro/E, then it works fine..
Has anyone had this problem and solved it?
Andrew Mansfield
Design & Development
KI, Green Bay, WI
