ECN Number on a drawing
STEVEG
We are working on getting change management in our company. Is there a way to get the ECN number automatically in our title block on our drawings. Is there an attribute we can add to our drawing formats?
No WTParts currently.
Steve Galayda
pwilliams-3
(To:STEVEG)
You can watermark this data on the representation.
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CE6828.722B3D60]
ssenthil
(To:STEVEG)
One can define a soft attribute (for example ECN_Number) for CAD document
and make this attribute as a designated parameter. This designated parameter
can be marked as the ECN Number in the drawing title block. If the end user
populates this WC CAD Document attribute with ECN Number(which can be
automated within ECN workflow), upon download and opening the model/drawing
in WF/Creo, the attribute value can be transferred to the title block. PTC
Manual "Using Pro/Engineer Wildfile with Windchill 9.1 (or equivalent latest
version) provides information about Windchill attributes interoperation with
Pro/Engineer WF".
Hope this helps.
Thank you and have a great time.
Best Regards
Swamy Senthil
Principal Solutions Architect, Swasen Inc
swamy.senthil@swasen.com(Email); 909 800 8423(M); 973 324 2729(W); 866
908 6561(F);
pwilliams-3
(To:STEVEG)
This requires a download operation to be executed. This may become problematic as to when that operation should be executed within the Change process.
[cid:image002.jpg@01CE683F.5697F270]
