ESI custom renderer with linked objects
TamasBiro
Hi all,
we are trying to add some custom attributes to the ESI map file which will be gathered and added by a custom ESIWTPartRenderer's adjustPartElement() function. If we initiate a publish on a part, then everything works as expected: our custom code is called, we read out the needed data and set it as the specific attribute's value.
The problem is, that if there is a link between a document and a part and I initiate the publish on the document (wan't the document, the related parts and the link in between to be published), then the part's custom renderer is not called... therefor the custom attribute won't get a value.
Any ideas how to force the custom renderer to be called even in case of an indirect publishing of the part (publishing the document that has a link to the part).
BR,
Tamás
The following (extended) functions are called in the following cases.
  1. When WTDcocument is published directly: function adjustDocumentElement() from class ESIDocumentsRenderer:
    public class ESIDocumentsCustomRenderer extends ESIDocumentsRenderer {
    	private static final Log logger = LogFactory.getLog(ESIDocumentsCustomRenderer.class.getName());
    	@SuppressWarnings("rawtypes")
    	@Override
    	protected Element adjustDocumentElement(Element elem, String paramString, Document document,
    			Collection paramCollection) throws ESIRendererException {
    		logger.info("Custom ESI Document Renderer Started");
  2. When EPMDocument is published directly: function adjustDocumentElement() from class ESIEPMDocumentsRenderer:
    public class ESIEPMDocumentCustomRenderer extends ESIEPMDocumentRenderer {
    	private static final Log LOGGER = LogFactory.getLog(ESIEPMDocumentCustomRenderer.class.getName());
    	@Override
    	protected Element adjustDocumentElement(Element elem, String group, Document document, Collection targets)
    		LOGGER.info("Custom ESI EPM Document Renderer Started");
  3. When WTPart is published directly: function adjustDocumentElement() from class ESIWTPartRenderer:
    public class ESIWTPartCustomRenderer extends ESIWTPartRenderer {
    	private static final Log LOGGER = LogFactory.getLog(ESIWTPartCustomRenderer.class.getName());
    	@Override
    	protected Element adjustPartElement(Element elem, String group, WTPart part, Eff[] effs, Collection targets)
    		LOGGER.info("Custom ESI Part Renderer Started");
  4. When an EPMDocument/WTDocument is linked to a WTPart the following functions are called:
       a) adjustPartElement() from ESIWTPartRenderer class
            b) adjustDocLinkElement() from ESIDocumentsRenderer class
            c) adjustDocumentElement() from ESIDocumentsRenderer class
    	@Override
    	@Override
    	@Override
