Error adding user to license group
rattmice
When adding a user to a license group, I'm getting the following error when clicking Finish in the popup window:
ATTENTION:
class [B cannot be cast to class java.lang.String ([B and java.lang.String are in module java.base of loader 'bootstrap')
Removing the below properties from the file IEConf/adapterservice.json doesn't help:
  • local.xxx.binaryMode=objectGUID
  • local.xxx.windchill.mapping.user.attributes=objectGUID
VladimirN
(To:rattmice)
Article - "Getting error: "java.lang.ClassCastException: class [B cannot be cast to class java.lang.String" while updating any "User"(adding or removing the group shows the error while finishing the popup) on "Edit" wizard after upgrade in Windchill PDMLink": https://www.ptc.com/en/support/article/CS394080
rattmice
(To:VladimirN)
Yes, I referenced the steps in the OP which didn't resolve the problem.
