I have received below inputs from PTC to resolve this issue. We should not be modifying serialized class once we assign serialVersionUID
Root Cause:
The Best Practice as you did:
There are a number of articles that have this message in it. Is this a new upgrade or related to some customization?
https://www.ptc.com/en/support/article/CS357861?source=search
See if above article is related.
Hi @MP_10433217,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
Root Cause:
