Executing Tasks
anis
Executing Tasks
I'm beginner in Windchill devlopment i need your help so much
i have to develop external application migrate documents after creating links between them to Windchill i want to know is there a task to link two documents and how could'i execute Tasks
Anis
use import function
navigator/product or library/utility/import export manager
you can find specs about to configure xml file searching "Windchill Export and Import" in windchill 10 online guide
Thanks Carlo for your answer but i need to develop application beacuase i have to link Windchill with Automation application so i need to develop an application to link both of them
you need to pass and create a wt.document on windchill or yust create a link on windchill that send you to automation sistem file? (because in case of migration you remove files from automation system and put on winchill lib, else you make link if you don't want to duplicate data on windchill) let me know
Let me explain you more please
I have application A and i have to develop application B that provide me the possibility to migrate data from application A to windchill and i have to do that with info*engine and the API SAK
