Version: Windchill 12.0
Use Case: Hello, We want to export and import workflow templates between Windchills with different versions. Is there a table showing version compatibility for this?
Description:
Which version are you exporting from?
Which version are you importing to?
I’ve had to do this several times between 13.x and 12.x.
I’ve not tested beyond those releases but I can tell you it was not difficult to do it.
Hi Graham,
Thank you for your answer.
One version 12.0.6 and the other 13.0.2
There is some good information and settings there:
No backwards compatibility.
Hi Avillanueva.
Thanks for the link, I will examine.
