Is there a Possibility to export an xlsx Table or anything similar from the Managed Collections Table?
From every other Table view you can export the data into an excel sheet.
Heres the Table Export for the Packages Content Table:
This would be a very useful tool if such an export would be possible from the Managed Collections.
This will be possible through customization. We need to add one action to export the list to excel sheet.
Ajit
Ajit
Thank you for your respond. I added the Action and now it works!
