Flexible Change and Resulting Object cardinality
mwaite
Under "Legacy" change there was a built in rule that prevented a revision from being the result of more than one Change Notice.  As soon as someone tried to add the revision to the results table of a second task, Windchill stopped them and threw up an alert telling them they could not do that.
That rule does not seem to be enforced under "Flexible" change.  I can have Rev A of the same Document be the result of any number of Change Notices.  That doesn't make sense in our company.
Does anyone know if there is a way to configure that rule in Flexible change?
Hi
Isn't the idea behind flexible change is to be able to manage cardinality between objects as you want ? have you tried to check if cardinality rule can handle your case ?
Regards
Using article CS268023 as a reference.
https://www.ptc.com/en/support/article/CS268023
The relation between the Change Task and the Resulting object is ChangeRecord2.
That didn't change with Flexible Change.
In past versions of Windchill there was a rule that the resulting object could only be in one ChagneRecord2 relationship.
That is no longer the default behavior.
I don't see a way to configure that behavior with the Change Association rules.
I usually write a listen to handle situation like this.
In short, you have a standard and you want the users to be forced to comply with it automatically. Correct?
If I understand you correctly a listener can be written to listen for the event in question. In this case, adding a resulting object to a Change Activity.
When your listener is triggered by the event code runs that checks if the standard is adhere to.
If it is not an exception is thrown which presents a window to the user with whatever you want to explain to them. In this case maybe something like object X is already a Resulting object on Change Activity Y on Change Notice Z and cannot be added to a second open Change Notice.
Is this the kind of thing you’re looking for?
David
David
mwaite
(To:d_graham)
Hi David,
Thank you for the response. I see how that would work, but ...
we have a strict "no customization" policy.
I know there is a fine line between configuring and customizing.
This used to be "Out of the Box" functionality in 10.2.
I'm hoping there is a way to "configure" Windchill to go back to the old behavior.
It's baked into all our training.
If Document 123 Rev A is a result of more than one CN, then the first CN to finish sets the state to "Released" and the second CN has lost the capability to re-work that Document.
I have a ticket open with PTC. Waiting to see what they say about it.
