Is it possible to hide IBA's (Standard and Global) from the attribtue drop down list on the search page? I dont think it is possible using profiles.
Thanks.
Malavika,
Profiles will hide the attribute from more than just the search page.
If you want to avoid all users from being able to search by certain attributes then you can update the <WT_HOME>/codebase/com/ptc/windchill/enterprise/search/server/SearchableAttributesByType.properties to remove the attribute from the type.
Example:
To avoid searching on End Item attribute for WTPart in the Advanced Search change
advancedSearch.wt.part.WTPart=CostEstimateType,CostVerdict,TargetCostWithUnit,CostEstimateConfidence,CostEstimateWithUnit,rohs_consumer,rohs_infrastructure,rohs_server,jig_a,jig_b,jig_101_regulated,jig_101_for_information_only,reach_svhc_candidate,reach_svhc_authorization,reach_svhc_restricted,reach_svhc_suspect,gadsl_and_imds_app_prohibited,elv_automotive,thePersistInfo.createStamp,iterationInfo.creator,defaultUnit,lock.locker,search_name,search_number,ownership.owner,source,state.state,partType,thePersistInfo.modifyStamp,iterationInfo.modifier,view.id,organizationReference,oemPreference,endItem,versionInfo.identifier.versionId,iterationInfo.identifier.iterationId,jobAuthorizationNumber,phase,contractNumber
to
advancedSearch.wt.part.WTPart=CostEstimateType,CostVerdict,TargetCostWithUnit,CostEstimateConfidence,CostEstimateWithUnit,rohs_consumer,rohs_infrastructure,rohs_server,jig_a,jig_b,jig_101_regulated,jig_101_for_information_only,reach_svhc_candidate,reach_svhc_authorization,reach_svhc_restricted,reach_svhc_suspect,gadsl_and_imds_app_prohibited,elv_automotive,thePersistInfo.createStamp,iterationInfo.creator,defaultUnit,lock.locker,search_name,search_number,ownership.owner,source,state.state,partType,thePersistInfo.modifyStamp,iterationInfo.modifier,view.id,organizationReference,oemPreference,versionInfo.identifier.versionId,iterationInfo.identifier.iterationId,jobAuthorizationNumber,phase,contractNumber
Lori,
Remvoing attribtues from serchableAttribtuesByType.proeprties was my first bet. However, these are IBA's(Global and Standard) that I have to hide.
Note : The IBA's show up in the query builder of the search page without having to add them explicitly in the serchableAttribtuesByType.properties
Therefore, is there another way of hiding these attributes from the search page ?
-Malavika
Document CS152986 suggests its an enhancement request.
This is not working in Windchill 10.1 M040 either. The requirement is to hide the Global attributes from the attribute drop down list on the search page.
Is there any option to selectively make attributes visible on the attribute drop down list on the search page depending upon the profile / user ?
Does anyone have a workaround to this issue ?
