I created a new drawing a part in one of my workspaces, but between switching to other projects I forgot which workspace I created it in. How do I search all my workspaces for this part and locate which one it is located in. Is there a way to search your workspaces?
within a workspace you can use the Search table functionalities (make sure you have the appropriate views).
If you want search within all your workspaces, you can use the advanced search, select the right object type (I think it is cabinet).
By default, the system knows that you have access to your workspaces and will return the results if any matches
Does that help ?
Can you walk me through this? I'm not seeing the object type "cabinet"
