How to Interrogate Log Files
kmorrison
I am looking for advice from the Windchill expert community on how you interrogate log files. For instance, I would like to take a log file, search for the string 'error ' in the content, and then eliminate lines which contain a pattern for unimportant strings. This should parse the log so that it only contains the lines of information which may contain notable errors. I currently only have Windows 7 text editors in my toolbox.
I am looking for the following type of advice.
1 - What is your method for interrogating logs to find relevant 'errors'?
2 - Is it possible to create macros in Microsoft word to filter out unimportant lines?
3 - Are there other text editors I should be considering which might make the task of interrogating logs easier (preferably free)?
Thanks!
Ken Morrison
Have also a look at the discussion Re: Log4j Log File Viewer
I'm using LogExpert
http://logexpert.codeplex.com
Very usefull for debuging. You can highlight some Keywords, filter and searching.
tswett
(To:kmorrison)
We use Splunk here. It indexes all the different logs within the Windchill environment - Apache, OS, Windchill - and you can even alert on specific keywords inside logs.
Thanks Björn, this link has some very good information.
