Hi All,
i want to add document as an attachment to a Problem report.
it can be easily done by UI.
my requirement is to add this attachment via API.
Please let me know how i can do this ? how i can edit/create new Problem report via API.
Vivek
Vivek,
you can try below code for adding Attachments for PR
Transaction tx = new Transaction();
if(ProblemReport != null){
try{
tx.start();
ApplicationData theContent = ApplicationData.newApplicationData(ProblemReport);
File theFile=new File(FilePath);
theContent.setFileName(FileName);
theContent.setUploadedFromPath(FilePath);
theContent.setRole(ContentRoleType.toContentRoleType("SECONDARY")); //if it’s secondary, use PRIMARY
theContent.setFileSize(theFile.length());
FileInputStream fis = new FileInputStream (theFile);
theContent = ContentServerHelper.service.updateContent(ProblemReport, theContent, fis);
ContentServerHelper.service.updateHolderFormat(ProblemReport);
PersistenceHelper.manager.refresh((Persistable)ProblemReport, true, true);
fis.close();
tx.commit();
tx= null;
catch(Exception e){
e.printStackTrace();
}finally{
if(tx!=null)
tx.rollback();
Hope it helps!!!
shreyas
Hi Sheryas,
Thanks for your help.
my requirement to create WTDoc first and then attach same document to problem report.
i am faing one issue while creating WTDoc via API,
i am using below code to create WTDocument,
package ext.wtdoc;
import java.beans.PropertyVetoException;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.IOException;
import java.lang.reflect.InvocationTargetException;
import wt.content.ApplicationData;
import wt.content.ContentRoleType;
import wt.content.ContentServerHelper;
import wt.doc.DocumentType;
import wt.doc.WTDocument;
import wt.fc.ObjectNoLongerExistsException;
import wt.fc.Persistable;
import wt.fc.PersistenceHelper;
import wt.httpgw.GatewayAuthenticator;
import wt.method.RemoteAccess;
import wt.method.RemoteMethodServer;
import wt.util.WTException;
import wt.util.WTPropertyVetoException;
public class CreateWTDoc11 implements RemoteAccess {
* @param args
* @throws WTException
* @throws ObjectNoLongerExistsException
* @throws IOException
* @throws PropertyVetoException
* @throws InvocationTargetException
public static void main(String[] args) throws ObjectNoLongerExistsException, WTException, PropertyVetoException, IOException, InvocationTargetException {
RemoteMethodServer rms = RemoteMethodServer.getDefault();
GatewayAuthenticator auth = new GatewayAuthenticator();
auth.setRemoteUser("wcadmin");
rms.setAuthenticator(auth);
System.out.println("Auth is done..");
rms.invoke("createWTDoc1", CreateWTDoc11.class.getName(), null, new Class[]{}, new Object[]{});
public static void createWTDoc1() throws WTException, PropertyVetoException, IOException{
String name="TESTWTDOCAPI";
String number="TESTWTDOCAPI";
WTDocument doc= WTDocument.newWTDocument(name, number, DocumentType.getDocumentTypeDefault());
ApplicationData theContent = ApplicationData.newApplicationData(doc);
String path="C:\\test.txt";
String filename = "test.txt";
File theFile=new File("C:\\test.txt");
theContent.setFileName(filename);
theContent.setUploadedFromPath(path);
theContent.setRole(ContentRoleType.toContentRoleType("PRIMARY")); //if it’s secondary, use “SECONDARY”
theContent = ContentServerHelper.service.updateContent(doc, theContent, fis);
System.out.println("22222");
ContentServerHelper.service.updateHolderFormat(doc);
System.out.println("33333");
doc = (WTDocument) PersistenceHelper.manager.refresh((Persistable)doc, true, true);
System.out.println("444444444444");
fis.close();
when i execute this code, i am getting below exception,
Exception in thread "main" wt.util.WTRemoteException: Unable to invoke remote me
thod; nested exception is:
java.rmi.ServerRuntimeException: Server exception; nested exception is:
wt.util.WTRuntimeException: Failed to initialize administrative domain.
at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:793)
at ext.wtdoc.CreateWTDoc11.main(CreateWTDoc11.java:46)
Caused by: wt.util.WTRuntimeException: Failed to initialize administrative domai
n.
... 2 more
Please let me know how i can fix this.
Vivek
