How to change the LDAP server port number.?
By default in Windchill 9.1 M062 it is 389, i want to change it to 3268.!
Can any tell me the procedure to do this change.?
I've never done this and I'm not in front of an instance to look, but I'll take a stab at it. Assuming Windchill DS, I'd start with looking through the properties and xconfs for port and 389. You can also look for the guide on ptc.com reference docs. If you're running as a service, you may have to uninstall/reinstall or reconfigure that. Is there no option after running dshome/server/bat/control-panel.bat ?
Are you trying to change your port number for WindchillDS or the port number that you use to talk to your internal LDAP such as Microsoft AD? If it's the connection string for your internal LDAP (MS AD) then you have to log into Info*Engine Admin, and update your connection string.
Let me know which one you are trying to accomplish.
