How to change group of queue say from Default to Default2
rlamkhade
Under the Queue management
How to change group of queue say from Default to Default2?
Can we do it from application level by right click?
ChrisSpartz
(To:rlamkhade)
In the queue manager, if you right click the queue you should see an 'Edit' option. If you click 'Edit', you will get a pop-up window, like the below, which gives you the option to change the group of the queue:
