To create a classification structure by importing a csv template.
Hello @RS_10128209
There is a windchill shell tool to convert csv to xml (wt.load.util.CSV2XML)
first you should prepare CSV file based on a csvmapfile.txt (WT_HOME\loadFiles\csvmapfile.txt)
there are method you need.
save csv to D:\IMPORTCSV
then use windchill shell command
windchill wt.load.util.CSV2XML -root D:\IMPORTCSV
XML file will be generated and this file you can load to Windchill by
windchill wt.load.LoadFromFile -u AdminUser -p AdminPassword -d D:\IMPORTCSV/sourceFile.xml -CONT_PATH \"/ORG_NAME/wt.pdmlink.PDMLinkProduct=PRODUCTNAME\"
Hope this can help
PetrH
Im enable to convert CSV to XML file its showing me the error related to header.
