How to create a new view version if Revise Transition is not set
SOLVED
Pearl
Hi
Is there any possibility to create a new view version of a WTPart where the "Revise Transition" is not defined?
If I use
WTPart mPart = (WTPart) ViewHelper.service.newBranchForView(part, "Manufacturing");
mPart = (WTPart) PersistenceHelper.manager.store(mPart);
I will get the error, that no revise transition is not defined. The method ViewHelper.service.newBranchForView does not throw any exception. This is thrown when storing the new WTPart.
Caused by: (wt.lifecycle.lifecycleResource/223) wt.util.WTException: Revise transitions not defined for current version in life cycle template.
I don't wan't to set any "dummy" revise transition for only creating a new view. Did anybody find a workaround?
Thanks for any help.
Re: How to create a new view version if Revise Transition is not set
Unfortunately it looks like that there is no possibility to create a new View Version without having set a revise transition.
A PTC support case didn't help me either.
Hi @brueegg,
Can you give it a try:
ViewHelper.service.newBranchForView(seed, "Manufacturing");
Shirish
My mistake. It is the same API. Smiley Sad
You might try PersistenceServerHelper instead of PersistenceHelper to persist the new part view version:
https://www.ptc.com/en/support/article?n=CS96632
I have seen PersistenceServerHelper work in cases where PersistenceHelper threw an exception.
Thanks for your tipp, unfortunately that doesn't work also.
