I am able to create MVC table builder for non persistable object, but records are not displaying in table,
hence can anyone provide solution?
FYI : "extends AbstractConfigurableTableBuilder"
Thanks.
Please refer to help center:- http://support.ptc.com/help/windchill/wc110_hc/whc_en/index.html#page/Windchill_Help_Center/WCCG_UIC...
Shriram.
Shriram.
Thanks Shriram,
i am able to create table but stuck in populate data.
Rows created but data not display.
Have you added the oid column?
columnConfig = componentConfigFactory.newColumnConfig("oid", "oid", false);
columnConfig.setDataStoreOnly(true);
tableConfig.addComponent(columnConfig);
Yes, i have added like this way
@Override
public ComponentConfig buildComponentConfig(ComponentParams arg0) throws WTException {
ComponentConfigFactory factory = getComponentConfigFactory();
TableConfig table = factory.newTableConfig();
table.setLabel("User Info..");
table.setSelectable(true);
table.addComponent(factory.newColumnConfig("Context", true));
table.addComponent(factory.newColumnConfig("Role", true));
return table;
You really need to have a oid attribute, otherwise it will not work.
@Getter
@Setter
public class ObjectToDisplay {
private String context;
private String role;
private String oid;
And to display the objects:
@Override
table.addComponent(factory.newColumnConfig("context", true));
table.addComponent(factory.newColumnConfig("role", true));
ColumnConfig columnConfig = factory.newColumnConfig("oid", "oid", false);
table.addComponent(columnConfig);
return table;
@Override
public Object buildComponentData(ComponentConfig var1, ComponentParams var2) throws WTException {
//get all the objects
List<ObjectToDisplay> list = new ArrayList<>();
return list;
This should work
import com.ptc.mvc.components.*;
import wt.util.WTException;
import java.util.ArrayList;
import java.util.List;
public class MyTableBuilderClass extends AbstractComponentBuilder {
@Override
table.addComponent(factory.newColumnConfig("context", "Context", true));
table.addComponent(factory.newColumnConfig("contextTeamRole", "Context Role", true));
table.addComponent(factory.newColumnConfig("fromUser", "From User", true));
table.addComponent(factory.newColumnConfig("toUser", "To User", true));
return table;
@Override
public Object buildComponentData(ComponentConfig arg0, ComponentParams arg1) throws Exception {
List<UserUtil> result = new ArrayList<UserUtil>();
result.add(new UserUtil("Product1", "Member", "User1", "User2","1"));
result.add(new UserUtil("Library2", "Member", "User1", "User2","2"));
result.add(new UserUtil("Project3", "Member", "User1", "User2","3"));
result.add(new UserUtil("Library4", "Member", "User1", "User2","4"));
result.add(new UserUtil("Project5", "Member", "User1", "User2","5"));
for (UserUtil userUtil : result) {
System.out.println("Context : " + userUtil.getContext());
return result;
// POJO : User Utility
public static final class UserUtil {
private String contextTeamRole;
private String fromUser;
private String toUser;
private String oid;
public String getContext() {
return context;
public void setContext(String context) {
this.context = context;
public String getContextTeamRole() {
return contextTeamRole;
public void setContextTeamRole(String contextTeamRole) {
this.contextTeamRole = contextTeamRole;
public String getFromUser() {
return fromUser;
public void setFromUser(String fromUser) {
this.fromUser = fromUser;
public String getToUser() {
return toUser;
public void setToUser(String toUser) {
this.toUser = toUser;
public String getOid() {
return oid;
public void setOid(String oid) {
this.oid = oid;
public UserUtil(String context, String contextTeamRole, String fromUser, String toUser, String oid) {
this.setContext(context);
this.setContextTeamRole(contextTeamRole);
this.setFromUser(fromUser);
this.setToUser(toUser);
this.setOid(oid);
public UserUtil() {
Thanks.
You need to provide an attribute called oid in your java object. Than you will be able to show any object in a table.
If you need your own views than you can extend the table as you did, otherwise AbstractComponentBuilder does work also.
Hello, there is a video of training for example from the documentation
https://www.youtube.com/watch?v=-14BSAwteVw&list=PLjm4gmbLQwoeqQSP7xUhCnInGknqTBAZV&index=2
