How to create my own ObjectCreateFormProcessor
AntonBagryanov
Hi to all!
I need to get the oid after persistable object creation. I have created my own FormProcessor that extends CreateObjectFormProcessor.
I have overrided create action for the promotion request object like follow:
<action name="create" selectRequired="true" ajax="component" uicomponent="PROMOTE">
       <description>Promote create wizard</description>
        <command class="ext.myComp.formProcessor.CreatePRFormProcessor" method="myMethod" windowType="popup"/>
         <includeFilter name="restrictGuestMembers"/>
      </action>
But my own method didn't called after user finish the wizard. As I know system call the execute(NmCommandBean) method. So how can I call my own method? Thanks
I was mistaken.
You should overwrite the doOperation() method and delete the line where object store. And delete method="..." in your *actions.xml file.
Example:
public class CreatePRFormProcessor extends CreateObjectFormProcessor
  @Override
  public FormResult doOperation(NmCommandBean paramNmCommandBean, List<ObjectBean> paramList) throws WTException
  FormResult localFormResult = new FormResult();
  localFormResult.setStatus(FormProcessingStatus.SUCCESS);
  if (paramList.size() > 0)
  localFormResult = super.doOperation(paramNmCommandBean, paramList);
  if (!continueProcessing(localFormResult))
  return localFormResult;
  for (ObjectBean localObjectBean : paramList)
  if ((localObjectBean.getObject() != null) && ((localObjectBean.getObject() instanceof Persistable)))
  String objRef = (new ReferenceFactory()).getReferenceString((Persistable)localObjectBean.getObject());
(Persistable)localObjectBean.getObject() is what I need
I was mistaken.
Example:
  @Override
