How to customize index.html file while exporting package contents
gmydoor-2
9-Granite
Hello all,
How to edit table view in index.html file obtained by downloading zipped Package in Windchill PDMLink?
Thanks.
1 ACCEPTED SOLUTION
No, I created the complete offline package functionality by myself with searchable structure, documents (pdf), line numbers, replacement parts, etc. It took a while, but the the efforts have paid off.
We also created a difference package, so two package version can be compared and only the difference will be exported. This function is very welcome for all the certification authorities.
7 REPLIES 7
This is a great question to which I have no answer. You might need to open a PTC Technical Support case for this one.
Thanks for the response. But PTC says there is no supporting API for this.
Hi @gmydoor-2
If PTC says there is not supported API, it does not mean it is not possible.
@BjoernRueegg for example created own function.
PetrH
Yes correct. I was just asking for the inputs on how can i proceed with our own customization.
I got an answer from support that this part is not customizable. So I programmed a custom export for packages...
Hi Thanks for the response. Did u customize index.html table ?
