How to download EPMDocumentMaster using API? wt.util.WTRemoteException: Unable to invoke remote method;
WhiteChen
8-Gravel
I want to use API to download EPMDocumentMaster, see the code as below:
package com.cisco.whichen2;
import java.io.IOException;
import wt.method.RemoteAccess;
import wt.method.RemoteMethodServer;
import wt.part.WTPart;
import wt.pds.StatementSpec;
import wt.pom.PersistenceException;
import wt.pom.Transaction;
import wt.query.QuerySpec;
import wt.util.WTException;
import wt.vc.config.LatestConfigSpec;
import wt.content.ApplicationData;
import wt.content.ContentHelper;
import wt.content.ContentItem;
import wt.content.ContentServerHelper;
import wt.content.FormatContentHolder;
import wt.epm.EPMDocument;
import wt.epm.EPMDocumentMaster;
import wt.fc.QueryResult;
import wt.query.SearchCondition;
import wt.fc.PersistenceHelper;
public class PartManager implements RemoteAccess{
  public static void main(String[] args) throws Exception {
  RemoteMethodServer rms=RemoteMethodServer.getDefault();
  rms.setUserName("wcadmin");
  rms.setPassword("wcadmin");
  Class argTypes[]={String.class, String.class};
  Object argValues[]={"29-8888-01.prt","C:\\temp\\"};
  System.out.println(PartManager.class.getName());
  rms.invoke("getEPM", PartManager.class.getName(), null, argTypes, argValues);
  public static void getEPM (String epmName,String path) throws Exception{
  Transaction tx=new Transaction();
  tx.start();
  EPMDocumentMaster cad = null;
  ContentItem primaryContent=null;
  if (epmName == null || epmName.trim().length()==0){
  System.out.println();
  QuerySpec qs= new QuerySpec(EPMDocumentMaster.class);
  qs.appendWhere(new SearchCondition(EPMDocumentMaster.class,EPMDocumentMaster.NAME,SearchCondition.EQUAL,epmName) , new int[]{0,-1});
  System.out.println(qs);
  QueryResult qr = PersistenceHelper.manager.find((StatementSpec)qs);
  System.out.println(qr.hasMoreElements());
  while(qr.hasMoreElements()){
  cad = (EPMDocumentMaster) qr.nextElement();
  String fullName = path + cad.getCADName();
  System.out.println("downloadFile>>>EMPDocumentMaster, writeContentStream:"+fullName);
  EPMDocument latest = (EPMDocument) wt.vc.VersionControlHelper.service.allVersionsOf(cad).nextElement();
  System.out.println("Get the latest version successful");
  primaryContent=ContentHelper.getPrimary((FormatContentHolder)latest);
  System.out.println("The primary content is:");
  ContentServerHelper.service.writeContentStream((ApplicationData)primaryContent,fullName);
  tx.commit();
The error information is:
com.cisco.whichen2.PartManager
Exception in thread "main" wt.util.WTRemoteException: Unable to invoke remote method; nested exception is:
  java.rmi.ServerRuntimeException: Server exception; nested exception is:
  java.lang.NullPointerException
  at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:788)
  at com.cisco.whichen2.PartManager.main(PartManager.java:36)
Caused by: java.lang.NullPointerException
  ... 2 more
Who can help me?
Thanks.
White
jmomber
(To:WhiteChen)
Could you give more detail as to how you're testing this? If you're calling PartManager.main(args) from the Windchill server where the class lives, say in a .jsp file, it should work fine.
Well, I guess calling the function and getting the Remote Method Server code should work fine....I didn't actually look at the getEPM code, which isn't your problem at this point.
jmomber
(To:WhiteChen)
Thanks a lot for your inspiring. My problem is resolved.
Can I ask one more question? I want get the part information in my workplace, when I select the part(show in picture), how can I get the part information by click customized button? I know I maybe need to use "NmCommandBean " and its method ".getSelectedOidForPopup()", but I don't how to use it, can you show me an example to use NmcommandBean class?
Best Regards.
White
RandyJones
20-Turquoise
(To:WhiteChen)
Check out the following thread:
Re: How to get Object details from selected row via custom action on separate jsp page
