How to export/import Access Control Policies?
ptc-5152676
Hi All,
I am wondering to export/import access control policies from all contex (Orgnization,Product,Library,Project)
Is there any option to do this?
If you want to load ACL only to Products and Libraries you can use the csv Loader like:
#AccessRule,user,domain,typeId,permission,principal,permissionList,state,parentDomainContainerPath
Example: <Windchill Home>\loadFiles\rule.csv
If you want to load Organization ACLs you have to use the XML syntax:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE ProductConfig SYSTEM "standardX10.dtd">
<ProductConfig>
<AccessControlRule>
<domainName>/Default</domainName>
<externalTypeId>WCTYPE|wt.folder.SubFolder</externalTypeId>
<lifecycleState>ALL</lifecycleState>
<WTPrincipalReference isInternal="true">
<groupName>CHANGE ADMINISTRATOR I</groupName>
<groupType>DynamicRole</groupType>
</WTPrincipalReference>
<grantPermissionSet>
<AccessPermissionSet>
<permissionField name="READ"/>
</AccessPermissionSet>
</grantPermissionSet>
</AccessControlRule>
</ProductConfig>
TZ
(To:BjoernRueegg)
Does anyone have a way to update/modify by java program?
