How to get Structure of Part Configuration ?
shindemayur
          I have created a Part Configuration. Now I want API to get structure of Part Configuration.
I tried
ConfigurationHelper.service.getNormal(partConfig);
this gives me Structure but not in proper order .
So I want as it is BOM structure.
How can I get this?
The area below the toolbar is divided into panes. The left pane displays the part configuration structure. The top node in the structure is the base part. ttrockstars
A part configuration structure may use a traceable child part that will allocate a part instance. In this situation the part master icon  is displayed.
The part configuration and assembly parts within the part configuration structure are expanded one level at a time using the expansion arrows to the left of each assembly row.
