How to get a document number that should contains product context name
kchaithanya
​Hi All,
one of my customers requirement is as follows
If he wants to create a document in XYZ product context, then while creating it, in number field if he manually enters 3434  then after creation of document, it should appear like ABC\1234\XYZ3434.
Where ABC\123 is static name which will be same for all documents and XYZ is the product context.
Can anyone suggest me how to achieve this ?
Krishna Chaithanya
You can modify the OIR and use "containerName" reference to do this.
<!-- Added by IS4522 REQID 897DF -->
<AttrValue id="number" algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator">
<Arg>AR</Arg>
<Arg>-</Arg>
<Attr id="containerName"/>
<Arg>-</Arg>
<Arg>{GEN:wt.enterprise.SequenceGenerator:TRCW_seq:5:0}</Arg>
</AttrValue>
Thank you
Binesh Kumar
<Arg>AR</Arg>
<Arg>-</Arg>
<Arg>-</Arg>
</AttrValue>
Thank you
Binesh Kumar
Hi Binesh,
Its working fine. Now getting Product Container Name in number field with WTDOCUMENTID_Seq sequence .Thanks a lot for sharing it.
But, I'd like to know whether it's possible to enter manual number which should append to Product Container name mentioned above instead of auto numbering ?
Krishna Chaithanya
