Hi!
I need to customize CheckinObjectFormProcessor. I need to get primary attached file that user insert in the checkin wizard. I've created my own CIObjectFormprocessor that extended OOTB CheckinObjectFormProcessor:
public class CIObjectFormProcessor extends CheckinObjectFormProcessor
public FormResult doOperation(NmCommandBean paramNmCommandBean, List<ObjectBean> paramList) throws WTException
FormResult localFormResult = new FormResult();
localFormResult.setStatus(FormProcessingStatus.SUCCESS);
// Need there to get new primary attachment file
localFormResult = super.doOperation(paramNmCommandBean, paramList);
return localFormResult;
localObjectBean.getParameterMap() can give me the Map with a lot of properties. But I can't to get the file I need. Please help.
Hi M Bagryanov,
you can try something like this:
/* (non-Javadoc)
* @see com.ptc.windchill.enterprise.doc.forms.CreateDocFormProcessor#doOperation(com.ptc.netmarkets.util.beans.NmCommandBean, java.util.List)
@Override
public FormResult doOperation(NmCommandBean arg0, List<ObjectBean> arg1) throws WTException {
System.out.println("*** I am in doOperation method");
HashMap map=getFormData(arg0);
java.util.Set setOfKeys = map.keySet();
java.util.Iterator iterator = setOfKeys.iterator();
while (iterator.hasNext()) {
String key = (String) iterator.next();
Object value = (Object)map.get(key);
System.out.println("\nKey: "+ key+", Value: "+ value);
//PRIMARY_FILE_wt.content.ApplicationData:1423826261835_filePath
if (key.startsWith("PRIMARY_FILE_wt.content.ApplicationData") && key.endsWith("_filePath")) {
String valueoffile = value.toString();
System.out.println("\t *** File is --- " +valueoffile);
File file = new File(valueoffile);
System.out.println("\t *** File Name - "+file.getName());
return super.doOperation(arg0, arg1);
@SuppressWarnings("unchecked")
protected static HashMap getFormData( NmCommandBean clientData ) throws WTException {
HashMap formData = new HashMap();
Map comboBoxData = null;
Map radioData = null;
Map textData = null;
Map textAreaData = null;
comboBoxData = clientData.getComboBox();
radioData = clientData.getRadio();
textData = clientData.getText();
textAreaData = clientData.getTextArea();
Map checkedData = clientData.getChecked();
Map uncheckedData = clientData.getUnChecked();
if (checkedData != null) {
Iterator itChecked = checkedData.keySet().iterator();
while (itChecked.hasNext()) {
formData.put(itChecked.next(), Boolean.TRUE.toString());
} // end if checkedData
if (uncheckedData != null) {
Iterator itUnchecked = uncheckedData.keySet().iterator();
while (itUnchecked.hasNext()) {
formData.put(itUnchecked.next(), Boolean.FALSE.toString());
} // end if uncheckedData
if(comboBoxData != null) {
System.out.println("Prniting the comboBoxData::::" +comboBoxData);
formData.putAll(comboBoxData);
if(radioData != null) {
System.out.println("Prniting the radioData::::" +radioData);
formData.putAll(radioData);
if(textData != null) {
System.out.println("Prniting the textdata::::" +textData);
formData.putAll(textData);
if(textAreaData != null) {
System.out.println("Prniting the textAreaData::::" +textAreaData);
formData.putAll(textAreaData);
return formData;
It will give you an file name which user selects in wizard.
I hope this helps you.
Shirish
