How to get "completedBy" Users of a workflow activity?
DimitriVanWijk
Hi All,
I would like to get the users that completed a workflow task and put them in a variable in order to reuse them in further tasks.
I tried to use expression robot with API to do that but have difficulties to find solutions : I get the Assigned activity or work item object but cant find a method to get the users that completed it.
Does someone know how to get the users that completed an activity from this activity?
Or if there is another way to do that ?
Thanks a lot for your answers.
Dimitri
Dimitri,
Once you have a WorkItem, you can can check to see if it
is complete with:
aWorkItem.isComplete();
And then do something like this:
aWorkItem.getOwnership().getOwner().getFullName();
to get the name of the owner of the work item.
Hope this helps,
Ron
Hello Ron,
Thanks a lot for this answer. Sur it helps !
I did'nt know for the "getOwnership" method so I will try this out and come back soon to give results !
Best regards,
