Can anyone provide an overview of how to handle the revision block in our drawings after migrating from Intralink to Windchill?
Currently (in Intralink) our formats call out the &proi_revision parameter. With Windchill, at this point it is my understanding that we will be calling out the &ptc_wm_revision parameter. However, evenwhen the formats are updated with this new parameter, when an existing drawing is migrated, the drawing still points to the old &proi parameter. There are a couple options for a quick fixfix--edit the text in the revision block or replace the format--both of these have the desired effect, but in a one-drawing-at-a-time kind of way.
Does anyone know of a way to do this in bulk--so that every existing drawing (10,000+) that is migrated will correctly show the &ptc_wm_revision when it is first retrieved from Windchill? Thanks in advance.
