How to make the user entries available in WTUser table
jselvaraj
8-Gravel
HI All,
Can you please someone tell how to make the user entries available in WTUser table?
I hope, the user entries will be created whenever the user tries to login and when we search the user in the participant administrator. Is there any code to sync?
Thanks for your help in advance.
John
KD
(To:jselvaraj)
Hi John,
In Windchill whenever you are creating any participant the entry typically goes to database table and directory server.
Windchill always tries to maintain the sync between the table entry and directory server, however, they can be out of synch time to time.
I am not exactly sure if this is what you looking for.
But you can check following Help Center link
Windchill Participant Status
http://support.ptc.com/cs/help/windchill_hc/wc110_hc/index.jspx?id=ParticipantAdminChp_ParticipantStatusOview&action=sho…
Managing Disconnected Participant
http://support.ptc.com/cs/help/windchill_hc/wc110_hc/index.jspx?id=ParticipantAdminMaintTbl&action=show
Kaushik
