How to remove a column from default table views
praseeth.moothe
Hi All,
I have a requirement to remove some OOTB columns(say, Number column) from all views in the Product->Folders tab. If anybody has worked on anything similar, can you please share the code/procedure to achieve this.
Any help would be appreciated.
Praseeth M
Bonjour Praseeth,
Hope you are doing good.
You can customise requirement defined Table View by getting the table id and mapping a equivalent java class in xconf to show or hide
the needed views.But this task will be intensive.
I am not sure about the other option , defining Hidden value Constraint for NUMBER in OIR for the object.
Sriram
Every view has a view id and you can override the OOTB class and u can hide the columns and map it to the same id.
But OOTB view will be affected fully. you need to hide based on some business logic..
thanks
