For a customer we need to do some soft typing on documents & parts. We also need to keep these definitions synchronized between different PDMlink environments, e.g. production, QA, training etc. What we do is to subtype from a standard WC data type and add the additional attributes there. The original data type is then made non-instantiable. How do we achieve synchronization without retyping everything? It does not seem possible to export these defs. I assume we can use the loader to import such definitions but I have not found sufficient documentation of the standardnn.dtd to allow me to describe a new soft type in XML. tia, Jan van Mastbergen
